DFB1 Support thread
Re: DoG's DFB1 Build
@markus0321, @DoG,
There's an experimental firmware to fix the Flash issue here: viewtopic.php?f=112&t=5889
If you have a chance, please let me know how it goes for you.
markus0321
No, I didn't find a solution, but a workaround, and it's not entirely good.Badwolf wrote: Tue Oct 18, 2022 9:18 pm @markus0321, @DoG,
New firmaware works better now I can use flashrom with standard EmuTOS and it works! Good job
There is also an improvement with a soft reset, because it works when I use flash, but with EmuTOS, when I turn off flash and TOS4.04 is working from the motherboard, unfortunately, after a soft reset, TT-RAM still disappears and just like I upload TOS4.04 to Flashrom it also disappears: - (
A soft reset doesn't work with TOS4.04 hm ..
@markus0321 can you please edit your post as we are a English only forum, thanks
markus0321
Sorryexxos wrote: Tue Oct 18, 2022 11:40 pm @markus0321 can you please edit your post as we are a English only forum, thanks![]()
markus0321
I did the reverse configuration with the new firmware.
EmuTOS in EPROM on Falcon motherboard TOS4.04 and unfortunately still bad graphics display during boot and later in TOS system.
It behaves weird because the system doesn't hang up, it just looks so bad.
I don't understand what this means, sorry. TOS4.04 doesn't detect TT-RAM, you have to declare it with a third party program at each reboot. It always disappears.markus0321 wrote: Tue Oct 18, 2022 11:11 pm when I turn off flash and TOS4.04 is working from the motherboard, unfortunately, after a soft reset, TT-RAM still disappears and just like I upload TOS4.04 to Flashrom it also disappears: - (
markus0321
Yes, I know that, I am surprised by such behavior. I uploaded EmuTOS to Eprom on the Falcon motherboard and then TOS4.04 to Flash only because the EmuTOS uploaded to Flash did not work previously and then I noticed such symptoms with graphics, but when I have TOS4.04 in both it is good. So, I set the active Flash jumper and the Eprom from the motherboard is still working? Maybe my UV EPROMs are defective or cause a conflict? I have HN27C4096ACC-10Badwolf wrote: Wed Oct 19, 2022 9:48 amI don't understand what this means, sorry. TOS4.04 doesn't detect TT-RAM, you have to declare it with a third party program at each reboot. It always disappears.markus0321 wrote: Tue Oct 18, 2022 11:11 pm when I turn off flash and TOS4.04 is working from the motherboard, unfortunately, after a soft reset, TT-RAM still disappears and just like I upload TOS4.04 to Flashrom it also disappears: - (
Marko
That's *almost* expected behavior. The blitter draws the Atari logo in TOS404 -- I'd expect to see nonsense if running with somethign else in the ROM socket.markus0321 wrote: Tue Oct 18, 2022 11:44 pm I did the reverse configuration with the new firmware.
However the fact you're getting *half* an Atari logo sounds like bus conflict. I'll try to scope my ROM chip enable line either tonight or tomorrow. Under EmuTOS in flash, that should never go active. If it does: we've found a problem.
markus0321
Approx. At night I can have some time because today I have another job after work, and if not, tomorrow I would check it in my Falcon, if you can find the cause and fix it.Badwolf wrote: Wed Oct 19, 2022 12:58 pmThat's *almost* expected behavior. The blitter draws the Atari logo in TOS404 -- I'd expect to see nonsense if running with somethign else in the ROM socket.markus0321 wrote: Tue Oct 18, 2022 11:44 pm I did the reverse configuration with the new firmware.
Thank you for the quick reply.
If you're using MAPROM, then I think this is a bug in the latest version -- it only works after a cold boot. That was an old bug that was fixed and appears to have come back.markus0321 wrote: Tue Oct 18, 2022 11:11 pm There is also an improvement with a soft reset, because it works when I use flash, but with EmuTOS, when I turn off flash and TOS4.04 is working from the motherboard, unfortunately, after a soft reset, TT-RAM still disappears and just like I upload TOS4.04 to Flashrom it also disappears: - (
Try v2.2 (attached).
- Attachments
- MAPROM22.PRG.zip
- (2.43 KiB) Downloaded 53 times
