exxos PSU 230V wiring
Repairs & upgrades.
Locked
Please note: Fitting is for guidance only. If not re-fitting the switch insulation boot, you must isolate mains connections with suitable heat shrink tubing . If not using a fused mains lead (no greater than 3amp fuse in the plug) , you should fit a 1 - 3 amp mains antisurge fuse in the live / hot wire between the mains connector and switch and insulate accordingly. Wires should be soldered at right angles on the switch.
230V WIRING - ORIGINAL GREY SWITCH
To wire the transformer to the original Atari switch, so as shown below...
230V WIRING - BLACK SWITCH
Notice the switch is mounted on the outside of the frame to give more clearance when fitting the mains wires.
NOTE: I strongly suggest fitting a new PSU switch when the PSU is fitted.
SWITCH
https://www.exxosforum.co.uk/atari/store2/#0032
PSU
https://www.exxosforum.co.uk/atari/store2/#0030
HOMEPAGE
http://www.exxosforum.co.uk/atari/last/p ... htm#PSUFIT
Re: exxos PSU 230V wiring
230V PRIMARY CONFIGURATION
Grey & Purple wired together. Blue & Brown as per UK wiring standard.
Locked
