Basilisk II Atari
General Discussion, STOS.
Moderator: troed
agranlund
Re: Basilisk II Atari
Post by agranlund »
stephen_usher wrote: Fri Jul 01, 2022 2:49 pm Meh! Intel code running under Rosetta runs faster than natively on the Core i7 chip.
(Technically Rosetta(2) still supports PowerPC and m68k if the support libraries etc. were present. Unfortunately they're not.)
Is it that good? I do remember Rosetta working quite well at the previous cpu switch so I wouldn't be surprised.
My very upgraded 2010 Mac Pro is still hanging in there but I'm starting to get tempted by one of those Apple Silicon machines :)
I'd like to try this on my TT, I've been following the progress constantly. Could someone be kind enough to TL;DR what rom to use & the base disk image you guys are using (so I don't have to go searching through the topic, I know I'm so lazy)
agranlund wrote: Fri Jul 01, 2022 4:52 pm
rubber_jonnie wrote: Fri Jul 01, 2022 2:24 pm Maybe a glitch for me, and certainly not the most performant, since it's Basilisk on an emulated TT running the Intel version of Hatari using Rosetta 2 on my Mac with Apple Silicon!!
You need to find a way to bring PPC into that impressive emulation stack of yours, and then top if off by running an AppleII emulator inside Basilisk :lol:
Have you ever seen Inception? I think that's where I'm headed!
Steve wrote: Fri Jul 01, 2022 5:46 pm I'd like to try this on my TT, I've been following the progress constantly. Could someone be kind enough to TL;DR what rom to use & the base disk image you guys are using (so I don't have to go searching through the topic, I know I'm so lazy)
Re: ROMs, do a Google search for Old_World_Mac_Roms.zip Download and unzip.
Which one to use? The LCIII, LC475 and LC630 ROM images (1MB) all seem to work fine.
The disk image is on @agranlund's project page.
agranlund
Post by agranlund »
There are some roms and disk images on my site under "Test Data"
http://www.happydaze.se/basiliskii/
The config file should already be set up for the LCIII rom + the disk image found in basilisk_extra1.zip, I think :)
I can't remember exactly what is on those other extra disk images, probably games.
The last executable posted in this thread is newer than the one on the website too I think.
If you wanted to try other roms then you should be able to find online a zip that has every Mac roms ever made, just like @stephen_usher mentioned.
frank.lukas
Post by frank.lukas »
agranlund wrote: Fri Jul 01, 2022 4:54 pm
I first thought you meant that the mouse cursor is unmovable but if you are able to set FAST in the control panel I assume you were able to move the mouse to get to the control panel but it's not acting properly?
Am I guessing correctly if I am guessing that the mouse is moving too slowly on your machine now?
I use the mouse cursor under ST-High, over the graphiccard no chance ...
The mouse cursor is moving to slowly even if in the control panel is it set to fast.
I use the 220627 from the Website ...
agranlund
Post by agranlund »
frank.lukas wrote: Fri Jul 01, 2022 6:33 pm I use the mouse cursor under ST-High, over the graphiccard no chance ...
Thanks @frank.lukas.
Since I cannot reproduce the issue here and I will have to try making a "blind" fix, all help trying to narrow down would be super valuable. If you have time and don't mind of course :)
Did it work in 220611?
Is the issue related to the resolution (ie; does it work, or behave differently, in something like 640x480?)
Is the issue related to the bit depth (16bpp is most likely going to use emulation, at least on most gfxcards, so I'm fishing for if it's related to that or not)
And just to be 100% sure my Friday brain understood correctly:
ST-High: mouse works, but moves too slowly
Graphics card: mouse does not move at all
or is it:
ST-High: mouse works fine
Graphics card: mouse works, but it is much too slow
frank.lukas
Graphiccard: mouse works but moves very very very slowly
I set the mouse from 8 to 0 in the inf but it do not help
agranlund
Post by agranlund »
frank.lukas wrote: Fri Jul 01, 2022 7:03 pm ST-High: mouse works, but moves too slowly
Hmmn, setting it to 0 should make the mouse completely unmovable.
That fact that it doesn't change anything could be some hint at least, thanks!
If you have some spare time at some point it would be super helpful to know which of the older builds was the last one that worked ok for you.
The latest version, uploaded just now, has an ACIA write fix, but based on what you are saying I doubt that'll do anything for the issue you are having.
(It does fix a mouse issue which happens *sometimes* when toggling zoom mode in ST or TT low resolution though)
agranlund
Post by agranlund »
The latest version should be faster.
Works on my machine, fingers crossed it works on others too :)
http://www.happydaze.se/wp-content/uplo ... 220701.zip
IMG_0304 copy.jpg (130.82 KiB) Viewed 1833 times
Return to “SOFTWARE”
