Page 15 of 19
Re: Server updates
Posted: Mon Jun 13, 2022 4:38 pm
by stween
exxos wrote: ↑Mon Jun 13, 2022 4:35 pm
For some reason it had reverted back to the previous old number
I deleted it out and put it back in again and now I think it is okay ?
Yup, looks good to me.
Re: Server updates
Posted: Mon Jun 13, 2022 8:43 pm
I need to fiddle with the site certs so things will get messy for a bit..
Re: Server updates
Posted: Mon Jun 13, 2022 9:24 pm
Did not realise I could put all the domains into one certificate file
I think the multiple domains was confusing everything as the bird ultimately would only allow "exxosforum" as the servername. Now it will accept others as it should do.
I also found windows actually has a certificate cache which can be cleared from the command prompt.
Problem being that this was the old server IP address. If I ping it, came up the correct new server IP address.
- 173410875-755acbfc-dfdb-43a2-b83c-9e82a661c870.jpg (40.94 KiB) Viewed 1625 times
After running the command from the command prompt in Windows, a lot of these problems went away!
Re: Server updates
Posted: Tue Jun 14, 2022 4:05 pm
by Darklord
I miss the "New Posts" button on the first screen...
Re: Server updates
Posted: Tue Jun 14, 2022 4:08 pm
Darklord wrote: ↑Tue Jun 14, 2022 4:05 pm
Was there one before ? can't remember, never used the option myself. But its in the quick menu anyway ?
I've added a link in the navbar, assuming that is what your missing ?
Re: Server updates
Posted: Tue Jun 14, 2022 5:07 pm
by Darklord
exxos wrote: ↑Tue Jun 14, 2022 4:08 pm
Yep, there was one before. I know, it's just a matter of dropping down the Q.menu and there it is but
I just got used to having it there and it's the most used button for me on this site.
Thanks for responding so quickly and adding it back!
Re: Server updates
Posted: Tue Jun 14, 2022 6:01 pm
I just tried registering a new test account and it seems broken. This is after we tested it before going live as well
So will fix that next..
- Capture.PNG (9.26 KiB) Viewed 1571 times
Seems that was the Recent Topics extension going nuts. Turned it off and on again...
Thought it was odd we not had any new registrations since the new server going live
Re: Server updates
Posted: Tue Jun 14, 2022 6:24 pm
Just got a email saying the forgot password thing doesn't work as well
- Capture.PNG (12.26 KiB) Viewed 1561 times
Re: Server updates
Posted: Tue Jun 14, 2022 7:30 pm
I opened up a topic on PHPBB's own forum
https://www.phpbb.com/community/viewtop ... #p15855526
But found some germans had the same problem. So I just manually created the tables and it seems to work now.
Re: Server updates
Posted: Tue Jun 14, 2022 9:30 pm
