EXXOS's new C1 build
Re: EXXOS's new C1 build
MIDI ports and reset switch done.
YM audio fix done.
AUDIO NOISE FIX
10uF 0805 cap first.
Track cut.
100K added.
MIDI noise fix done in this post. viewtopic.php?p=87537#p87537
Salvaged a couple of parts from my previous C1 build just for quick testing. Still got a few bits and pieces yet to do but first power up as a success at least! Probably won't get time now until next week to do anything else.
Floppy power cable added. I also put some hotsnot on there is a bit of strain relief.
The X2 MIDI audio fix previously was to wire pin 1,2,4, on JP3 prevent audio noise issues when not using the midi synth board.
The fix is advised for the C3 board involves fitting 100K resistors as outlined in THIS post.
Some IO added. Now to test the MIDI synth :)
<lazy previous video>
Oddly now it sounds like there is some AGC stuff going on now with my TV :shrug: Plugged a ST2VGA adapter in to use the audio out on my headphones and volume seems fine. Feking cheap TV's :roll:
I guess it's possible the audio output volume is to high causing the problem as it "limits" on more bass notes. Its sorted in the audio fixes anyway :)
Locked
Return to “H5 C1 USER BUILDS”
